NewFrequency
Feb 19, 2020Aspirant
Orbi RBS20 hardwired to RBR20
Hello. Have a RBS20 connected hardwired to RBR20. With no cable between I can see both in my app. With the cable connected The RBS20 disapears. I can se my computer, phone etc. connected to the RBR vi...
Feb 19, 2020Guru - Experienced User
Do you mean the Orbi app?
Do you see the RBS in the RBRs web page using a web browser when it's connected via LAN cable to the RBR?
Is the RBS directly connected to the RBR or is there a switch in between?
Disable Daisy Chain on the RBR. Under Advanced Tab/Advanced Settings/Wireless Settings.
NewFrequency
Daisy Chain on the RBR has always been disabled.
