NickRandom
Jan 03, 2021Initiate
Orbi RBS20 satellite not synching SSID
I have an RBK23 system, where I am current using only one satellite, in AP mode and with ethernet backhaul. After initial testing I have changed the default SSID and password to the one I want to use...
- Jan 03, 2021
Yes, of course, the satellite should pick up the router SSID/password when it sync's. ("Instantly", I'm not so sure. But, certainly within minutes.)
If this Orbi is less than 90 days old, Netgear offers 90 days of "complimentary" support. Sounds like a great question to ask them.
Just for a lark, how about doing a Factory Reset, then syncing the satellite over WiFi (in the same room).
See if the satellite picks up the router SSID before changing to ethernet backhaul.
CrimpOn
Jan 03, 2021Guru - Experienced User
- NickRandomJan 03, 2021Initiate
Thank you Sensei. I bow to your superior wisdom! :smileyvery-happy: (Sorry there is no bowing emoji).
To make it work I unplugged the ethernet backhaul, performed a factory reset on the satellite and then synched. The satellite updated pretty much instantly to the new SSID. So it does seem like the ethernet backhaul was causing some strange behaviour, but it is all good now.
