rant22
Jun 29, 2020Aspirant
orbi RBS20
I recently purchased an Orbi Sattellite RBS20 to add Wifi coverage in my house. My existing router is an RBR20. I have tried setting up the new sattellite through the phone app and it will not jo...
Jun 29, 2020Guru - Experienced User
Did you sync the RBS to the RBR by pressing the sync button on the RBS then RBR?
Review the installation guide for additional help on getting the RBS conencted to the RBR.
rant22
It is an Arris 27BC from Windstream. It works fine with the existing Orbi router with 1 sattellite. Just can't get the new sattellite to communicate with the system. Thanks.
