JoElliott
Mar 17, 2021Aspirant
Orbi RBS20
Hi, I have an Orbi RBS20 that I bought around a year ago. When I first bought the product, I remember speaking to NetGear as I couldn't connect to my laptop. They asked which Broadband provider I...
vajim
Mar 17, 2021Master
then you have something else going on
modem?
Router?
JoElliott
I have the Orbi set up to the BT router (I think) and this works for every other device
- vajimMar 17, 2021Master
JoElliott wrote:I have the Orbi set up to the BT router (I think) and this works for every other device
when you say orbi are you talking about the orbi router or sat?
if you're running 2 routers you may want to read this:
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
- JoElliottMar 17, 2021Aspirant
Thank you.
It's an Orbi sat.
This is then connected to my BT router
JoElliott wrote:Thank you.
It's an Orbi sat.
OK...but that requires special configuration. Changing PCs, or a new laptop should not made difference. Did it work before?
But it sounds like you're trying to login to your orbi router and I gave you the correct URL
just make you sure you have the 2 routers set up correctly or better yet get rid of the BT router if you can.
