Naturaledge42
Dec 20, 2017Follower
Orbi RBS40 satelite stopped working and flashes led codes after V2 firmware update.
Satelite led flashes white 10 times then flashes orange once then repeats. Contacted support and they had me reset both the router and satelite, twice. After 2nd reset light sequence changed to 10 wh...
jsee
May 06, 2018Aspirant
Hi Appreciate if you can help.
Updated my RBS40 Satellite to latest firmware V2.xx and it's now not working. Unable to connect to my RB40 router and can't be detected by Netgear Apps. The white LED ring light keeps flashing, will not go off despite leaving it for more than 10 mins.
Tried factory reset, problem still persist. Any suggestion on how this can be fixed?
Thanks in advance for your help.
May 07, 2018Guru - Experienced User
