RodDJ's avatar
RodDJ
Follower
May 05, 2020
ORBI RBS50 - WiFi Speed does not match speed from the router
I have fiber interenet coming into my house from a company named MiFiber. I have hard wired my laptop to the modem ghe MiFiber modem and ran a speed test. That test revealed that I am getting 175 mbps download speed. But my Orbi and Orbi sateliite are only delivering 50 Mbps download speed. How do I troubleshoot and correct this issue.?
1 Reply
  • What Firmware version is currently loaded?
    Are you wired or wireless when speed testing from the RBR or RBS?
    What devices do you have connected?
