gusperrysmom's avatar
gusperrysmom
Orbi RBS50 and AP Isolation settings. How do you change?
I am trying to add a Logitech Harmony Hub to my system.  Troubleshooting in Logitech says: "Some routers have a setting that prevents two Wi‑Fi devices from communicating with each other, and will o...
  • gusperrysmom's avatar
    gusperrysmom
    Dec 01, 2017
    Thanks for responding so quickly.  So ... I wonder what's causing the problem with the inability of the app to connect to the Harmony if it's not the Orbi.  More investigating ...
