gusperrysmom
Nov 30, 2017Aspirant
Orbi RBS50 and AP Isolation settings. How do you change?
I am trying to add a Logitech Harmony Hub to my system. Troubleshooting in Logitech says: "Some routers have a setting that prevents two Wi‑Fi devices from communicating with each other, and will o...
- Dec 01, 2017
Thanks for responding so quickly. So ... I wonder what's causing the problem with the inability of the app to connect to the Harmony if it's not the Orbi. More investigating ...
TheEther
Dec 01, 2017Guru
Netgear Wi-Fi routers, including Orbi, do not block devices from communicating from each other on the non-guest networks. AFAIK, there is no option to change this.
The situation is different for the guest networks. There is an option, "Allow guests to see each other and access my local network", that can be toggled. This option is kinda inane. There really should be an option for guests to see each other but NOT access the local network.
gusperrysmom
Dec 01, 2017Aspirant
