Jazzik
Nov 23, 2019Aspirant
Orbi RBS50 Backhaul, is it possible to confirm if my Satellites are using the ethernet backhaul?
When I look at connected devices, both satellites are displaying connected 5ghz, I would expect this to have changed to wired the same as the other devices.
Jazzik
Nov 24, 2019Aspirant
Router Firmware Version V2.3.5.30
I'm actually connecting the router to a Meraki Switch, which then goes into a Palo Alto VM300 firewall before reaching my ISP router.
Is the Orbi system operating in Router or AP mode?
AP Mode as I have the VM300 firewall handling all of my security and routing.
What is the Mfr and model# of the ethernet switch in the configuration?
The satellite is just connected to a dumb NG switch, through a patch panel which runs to my downstairs
Nov 25, 2019Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration? Reason for asking is that some switches can cause problems with Orbi satellites being connected via ethernet. Particularly managed or green ethernet featured switches.
Best way to confirm the RBS is connected via ethernet is to check the status on the RBR connected devices web page. The RBS will either show wireless or wired.
