Thori's avatar
Thori
Follower
May 31, 2020
Orbi RBS50 big problem
Okay so i have tried like everything and my orbi RBS50 keep **bleep**ing up.. like its The biggest piece of **bleep** i have ever used my money on. Like i connect my router to The internet and then go up with The satalite where it shall stand but it aint working AS it should. Can anyone plz help me because netgear wont
  • CrimpOn's avatar
    CrimpOn
    It is true that Netgear provides "complimentary support" for only 90 days after purchase.  If this is a new purchase, then there is a link on the product registration web page to contact support.
    I believe the instructions recommend setting up the RBS50Y in the house and near to the Orbi router before moving it outside and securing it to a wall.  Did work before moving outside?
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
