Akoek's avatar
Akoek
Follower
Feb 13, 2024
Orbi RBS50 Bricked?
Hello,
I have found a topic regarding the same issue I have:
https://community.netgear.com/t5/Orbi-Wi-Fi-5-AC-and-Orbi-with/Is-my-13-month-old-RBR50-bricked/td-p/2009904
going over all the steps in the message from  pbarham on ‎2020-11-23, I could not get furhter at the step when the Orbi should re-boot. In Terminal I'm not getting the message:
Hit any key to stop autoboot: 2
Anyone an Idea on how to fix this?
I have tried to set the rate on 9600 & 115200... but nothing helps!
thanks!
1 Reply
  • FURRYe38's avatar
    Last resort would be to try a 30-30-30 reset. If this all fails, then RBS needs to be replaced.
    Good Luck.
