johncvv
Mar 19, 2021Aspirant
Orbi RBS50 broadcasting disabled guest ssid
I am having an issue with my RBS50 satellite broadcasting the guest ssid even though it is disabled. I am not able to see if from my clients but it shows up in WiFiinfoView. I have verified it is b...
- Mar 19, 2021
I updated to V2.7.2.104 from V2.7.2.102. Did factory reset and setup twice. Both times I noticed that my router and satellites were transmitting NETGEAR-guest ssid unsecured. I have reverted back to V2.7.2.102 and my issue went away. I did manual updates from web gui. Has anyone else seen or noticed this? Please let me know, thanks. Netgear please look into this matter.
I have seen this too. I noticed if you let the system run for about 4-5 min, it corrects itself. The guest ssid will go away, but this is a major issue because before it does, anyone can connect with no password. I have switched to Voxels and all is well. If factory firmware would work as intended, I would be on it.
808stateofmind
Mar 19, 2021Star
