novs1985
Jul 29, 2020Tutor
Orbi RBS50 can't reset
After the latest firmware upgrade, 2.5.1.16, i noticed one of my satelites was disconnected. I tried to resync, nothing, i then tried to reset via paperclip, nothing. The power light is on green, b...
Jul 29, 2020Guru - Experienced User
WIth all cables disconnected from the RBS. Pressing the reset button on top then release doesn't how a blinking WHITE led on top?
Swap power adapters to see if this changes anything.
If nothing seems to help, you might want to make contact with NG support to see about what options are available.
- novs1985Jul 29, 2020TutorAll wires are disconnected except the power code. No lights glowing on top. I can try the power adapter swap but it’s getting power. The light on the back where power adapter goes is glowing a light green I think.
- FURRYe38Jul 29, 2020Guru - Experienced User
