novs1985
Jul 29, 2020Tutor
Orbi RBS50 can't reset
After the latest firmware upgrade, 2.5.1.16, i noticed one of my satelites was disconnected. I tried to resync, nothing, i then tried to reset via paperclip, nothing. The power light is on green, b...
M0381U5
Jul 30, 2020Guide
Yep, Same problem.
Updated the Firmware yesterday.
Today satellite device is not recognised as being connected.
Power cycled, using switch and unplugging for about 10 mins. didn't work.
Reset as per instructions (satellite does not get solid white led light ring), Run both Orbi app 'add satellite' and PC browser 'add sattelite', neither Worked.
Just over 6 month old.
Apparenlty Netgear doesnt provide support after 90 days...WTF?
No answer from support, even when I select to subscribe to their extortionary Gear Head support.
I have extensive ARLO (formally netgear) security camera system that now doesnt work as I dont have mesh connectivity.
THIS IS AN ABSOLUTE DISGRACE!!!
Jul 30, 2020Guru - Experienced User
Make sure both RBR and RBS FW was updated.
Was FW updated thru the RBR auto update feature, Orbi app or did you manually download and apply the FW files?
Be sure to bring the RBS near the RBR, same room, 6-10 feet away and press the sync button on the RBS then RBR to see if it will sync properly.
M0381U5 wrote:Yep, Same problem.
- novs1985Jul 30, 2020Tutor
I updated it through the browser. My RBR and other RBS is updated. I tried the power supply and bringing it next to the RBR. It appears to be unresponsive.
I guess i can call netgear, i doubt they will give me the time of day since i am out of warranty.
- FURRYe38Jul 30, 2020Guru - Experienced User
Contact the forum moderator to see what your options are.
Good Luck.
Forum_Moderator Any suggestions, i can't even find the phone number for support.
- M0381U5Jul 31, 2020Guide
Managed to get intouch with Netgear.
Support;
Hold in Reset with pin for 30 secs
Unplug power while still holding in pin for 5 secs
Then plug power back in again while still holding in pin for an further 30 seconds
Power button light will flicker red for a sec.
remove pin and begin pairing process again.
This didnt work for me and satellite was found to be faulty
Received RMA
Took RMA to retailer and fortunately the replaced immediately.
Good luck.
- tomschmidtJul 31, 2020Virtuoso
Even though Netgears tech support is only 90 days, your hardware has a 1 year warranty. Since you stated it is 6 months old, contact them for an RMA since their firmware update bricked the hardware. This issue unfortunately is all too common with NG lately, they have good hardware but lousy firmware.
- novs1985Jul 31, 2020Tutor
It is more than 1 year old. I will call netgear. I think I am SOL. It's complete garabage if they dont do something.
- MstrbigJul 31, 2020Master
I had a similar issue. One of mine out of the box took over 1 minute to turn amber. Take a paper clip, make sure the green light is on next to power button. Hold the reset button in until the green light turns amber. Let go, when it turns amber. If it is not defective, it should flash white on the top.
