Tarotwitch51's avatar
Tarotwitch51
Orbi RBS50 daisy chaining satellites from different sets
We've had a set of Orbi RBS50 router and 2 satellites for a few years now.  Recently acquired a couple more RBS50 satellites from a different set and am trying to daisy chain one off of one of our existing satellites.  Not having any luck doing this.  Would love some ideas....
  • CrimpOn's avatar
    CrimpOn
    Would you please try this:
    • Locate the new satellite in the same room as the router.
    • Use the Orbi web interface menu item Add Orbi Satellite (see page 12 of the User Guide:
      https://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf )
    • Verify that the satellite was successfully added and shows up on the Attached Devices display.
    • Then, move the satellite to the desired location, power it up, and see if it connects to the nearest Orbi device.
    Thanks
    • Tarotwitch51's avatar
      Tarotwitch51
      Thanks for the suggestion, unfortunately it did not work.  Our set of Router and 2 Satellites works great.  I was trying to Daisy Chain from one of our original satellites, to a satellite from a different set and I'm wondering, since all the units that come together as a set have the same password, if me trying to add one from a different set, is part of the problem.  Here's what I've tried so far.
      I took the unit I'm trying to add to our set, into the room where the Orbi router is, plugged it in, turned it on and hit sync.  It went through the process but wasn't found by our set.  Then I connected them with an ethernet cable and tried again.  Nope.  So then I tried pressing the sync button on both units to see if they'd find each other.  Nope.  I even took the newer satellite out to our original unit and tried all of the above.  No luck.  If I can't connect to the newer satellite to change it's password, I'm probably out of luck?
      • CrimpOn's avatar
        CrimpOn
        I know it sounds tedious, but did you actually open the menu item "Add Orbi Satellite" and follow the procedure one step at a time?
