gabopagan's avatar
gabopagan
Orbi RBS50 firmware at V1.4.0.18 I need the img files to update it
I have an Orbi Satellite with firmware at  V1.4.0.18. I understand I need to get img files supported by this firmware to manually udate it to get it to par with the rest of my network. Please advise ...
  • FURRYe38's avatar
    Apr 22, 2019
    All downloadable files are here:
    https://www.netgear.com/support/product/RBS50.aspx
    You first need to apply v2.0.0.74, then you can go directly to v44.
    Connect a wired PC to the RBS and wait for the PC to get an IP address from the RBS. Log into the RBS at 192.168.1.254 with a web browser once PC has an IP address then send the FW files to the RBS.
