meikaina
Jul 11, 2020Follower
orbi rbs50 FW corruption
I was setting up my mesh wifi today and along the way i automatically updated the FWs and long story short it didn't turn out well. MY router-wiki is up but can't link to sattelite as it's apparently...
- Jul 13, 2020
I would try this first on the RBS:
What you need to do is factory reset the RBS. Wire connect a PC to the 1st satellite. Already have the most current FW version files downloaded on to this PC.
Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minutes. The PC will get a IP address from the satellite. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites to the RBR.
meikaina wrote:I was setting up my mesh wifi today and along the way i automatically updated the FWs and long story short it didn't turn out well. MY router-wiki is up but can't link to sattelite as it's apparently the FW is corrupted. (red flash on power led) and blinks white ring.
Support recommends me sending it back but i hear some people fixed it using the steps in the link https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
Question is, how? as the steps are for the router and not sattelite.
What do you do differently if its a sattelite problem.
This person seemed to have done it somehow https://www.reddit.com/r/orbi/comments/9dvtz5/orbi_satellite_corrupt_firmware/
Jul 13, 2020Guru - Experienced User
