Strona
Feb 18, 2024Tutor
Orbi RBS50 lag spikes
Hi community, I'm struggling since few days on my Orbi RBR50 + RBS50 setup. I'm having a lot of lag spikes with a very hig latency (more than 1000ms) on my satellite, but not on my router. H...
CrimpOn
Feb 18, 2024Guru - Experienced User
How does the web interface Attached Devices screen show the satellite connection? (Good? Fair?)
Strona
Feb 18, 2024Tutor
Hi,
Thanks for your reply!
It’s showing as “Good”.
- CrimpOnFeb 18, 2024Guru - Experienced User
This seems to indicating that the WiFi connection between router and satellite is not operating at full capacity.
This 5G WiFi link uses channel 157 in North America and channel 108 in the rest of the world. (Europe, Japan, etc.)
One test would be to temporarily change the connection between router and satellite to an Ethernet 'wired' connection.
I keep a 100ft. Ethernet cable (under $20 on Amazon) in a drawer for just this purpose. When I get a chance, I string the cable through the house, down the stairs, etc. from one place to another. Perform the test, and then wind it back up. If the system performs as expected with a wired connection, then there is clearly something amiss with the WiFi connection.
One obvious step is to restart everything (not reset, just restart)
- StronaFeb 19, 2024TutorHi,
I wired the satellite while having the huge latency.
By magic, it went as low as I got from the router. If I remove the cable, latencies are starting again to come back.
It seems the issue is located into the WiFi between the router and the satellite, as you wanted to check.
But to be honest I don’t see how to fix it…
Regards.- CrimpOnFeb 19, 2024Guru - Experienced User
Well, the obvious solution is to 'wire the satellite permanently', which is almost always impractical. WiFi extenders and mesh WiFi systems were created to address the problem of installing Ethernet cables in existing buildings.
Alternatives to physical Ethernet cables include:
- Multimedia over Coax Alliance (MoCA).
https://en.wikipedia.org/wiki/Multimedia_over_Coax_Alliance
Many houses have coax cable connecting almost every room in the house, often running along the eaves, through the attic, etc. If coax cable is available, MoCA works very well. A pair of MoCA adapters creates what appears to be an Ethernet connection. - Power Line. https://en.wikipedia.org/wiki/Power-line_communication uses the house electrical wiring in much the same way. It is more 'touchy'. Adapters on the same electrical circuit give the best performance and there can be issues with certain circuit breakers. It definitely does not deal with circuits on separate panels. A pair of the highest capacity Power Line adapters would run about $100US. (I use Power Line to connect two Tivo units to the internet.)
- Wireless Bridge. Typically used to extend a network to a remote building (barns are the most common topic), wireless bridges also create the appearance of an Ethernet connection.
Users cannot choose which WiFi channels to use for the router-satellite connection.
One other possibility is to try moving the router and satellite around a bit. Who knows???
If it was possible to figure out what was interfering with the router-satellite WiFi connection, it might even be possible to shield those WiFi radio antennas with a judicious placement of metal to block the interference. (It probably IS possible, but I certainly have no clue on how to detect that interference or figure out where it is coming from.)
