KLS54
Nov 23, 2021Aspirant
ORBI RBS50 MOBILE CONNECTION
Hello I have a RBS50 and for the last month and a half I have had major troubles with our mobile devices. The internet will not work on our cell phones, but will the laptop. Is there anything...
KLS54
Nov 25, 2021Aspirant
I did try again with the correct serial number on the router and I was able to create an account. I am able to log in to manage orbi now.
CrimpOn
Nov 25, 2021Guru - Experienced User
Are there still issues to be resolved?
- KLS54Nov 26, 2021Aspirant
Hello,
No nothing has been resolved. I replied 2 times because I was able to create a log in to the orbi. My reply I had said I could not.
Still not able to load any webpages or apps on mobile. Laptop and ring cameras are fine.
- CrimpOnNov 26, 2021Guru - Experienced User
Now that you have access to the Orbi web interface, it may be helpful to look at the Attached Devices page.
Does the page say Access Control is Turned On or Off (top center of the page)?
Scrolling down the list of devices, do the devices that are not working appear on the list,have IP addresses, and show a Good connection to Orbi units?
It says access control turned off.
My phone does have an ip addres.. It appears it is connected 5g.
