ASGILL
Jan 15, 2022Guide
Orbi RBS50 no internet
I have Orbi RBR50 with RBS50 satellite, from last few months I started loosing internet on any device that connected to satellite, so I have factory reset whole system, satellite was able to connect a...
Jan 16, 2022Guru - Experienced User
So its only the 1 satellite loosing connection?
have you tried moving it around to see if its a location or interference issue?
How far from the router is it?
What are your interior walls made of and how many are between the router and the satellite?
ASGILL
Jan 17, 2022Guide
10-15m, yes tried most of the solutions, incuding factory reset, Sat works for some time, devices connected to this particuar SAT show good signal strenth but no internet till I turn it off and devices can connect to RBR50, trouble is moving around bit further in house, RBR50 does not have range that far, hence this SAT
