JeazusOne
Sep 17, 2018Follower
Orbi RBS50 not connecting
Hey guys,
Recently I have been having issues with my RBS50, It doesnt want to connect to my RBR50 no matter what I do. I even performed multiple factory resets on both devices and my RBS50 does...
Sep 18, 2018Guru - Experienced User
What FW is currently loaded?
Try doing a factory reset with the satellite while in the same room as the Router base. Reboot the router base before doing the reset on the satellite. The top led should slowly pulsate white which indicates it's ready and then press the synce button on the Router then press the sync button on the satellite.
If any of this fails, make contact with NG support and ask about an RMA.
