Crispin123
Aug 24, 2021Tutor
Orbi RBS50 reboots everyday
I have an Orbi mesh network... and it has this reboot problem - approximately every day it rebots. Recently I internet supplier upgraded their router and I hoped that would solve the problem ....
- Sep 07, 2021
Just a small update...
On my ISP router I have enabled DMZ mode that points to the address of the Orbi (192.168.1.10)
On the Orbi I have set it up as a router - and it shares adresses in the family of 10.0.0.1 etc...
The system has now been running 6 days without a problem and without a reboot.
I have also enabled the wifi network on the ISP router (as a backup in case of problems) - and this does not appear to disturb anything.
On the ISP router I have also attached a computer on a fixed address (running linux) that I need to log into from outside - and this continued to work - I have also an internet telephone on the router of the ISP.
The key appears to be using a fixed address for the Orbi - and running the Orbi as a router.
Many thanks to FURRYe38 for their insight.
Aug 25, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Traffic Meter.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
Crispin123
Aug 25, 2021Tutor
Thanks for the useful information
Firmware V2.7.3.22 (GUI language version V1.0.0.375)
The router supplied by the ISP is a Icotera Model: i4850-00.
The problem I have is that the walls are ~ 1 m thick stone and the Orbi satelites can talk through the wall when they are placed each side...
The reboot usually happens when I am connected to the server unit - and happens during video calls - and this makes it very annoying. I have enabled the WiFI on the Icotera router with a different Wifi name - and this works without problem [i.e. never hangs] so I can join that network if I am making a critical video call.
Each firmware update I hope that Netgear would solve this problem. I have tried many variations to try and find a solution to this continuing rebooting - but so far I have failed. I am not alone with this problem and I would have thought that Netgear would either offer a hardware fix - or fix the firmware - instead their service department say that I should throw it away and buy something new : unbelivable.
I will go through your list of suggestions ... but I fear that there will be no magic solution
- FURRYe38Aug 25, 2021Guru - Experienced User
What mode is the modem working in? Router or Bridge?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopYou might try option #3...
- Crispin123Aug 25, 2021Tutor
Thanks for this suggestion re the AP mode (option 3) I will try this ... :)
