Crispin123
Aug 24, 2021Tutor
Orbi RBS50 reboots everyday
I have an Orbi mesh network... and it has this reboot problem - approximately every day it rebots. Recently I internet supplier upgraded their router and I hoped that would solve the problem ....
- Sep 07, 2021
Just a small update...
On my ISP router I have enabled DMZ mode that points to the address of the Orbi (192.168.1.10)
On the Orbi I have set it up as a router - and it shares adresses in the family of 10.0.0.1 etc...
The system has now been running 6 days without a problem and without a reboot.
I have also enabled the wifi network on the ISP router (as a backup in case of problems) - and this does not appear to disturb anything.
On the ISP router I have also attached a computer on a fixed address (running linux) that I need to log into from outside - and this continued to work - I have also an internet telephone on the router of the ISP.
The key appears to be using a fixed address for the Orbi - and running the Orbi as a router.
Many thanks to FURRYe38 for their insight.
Crispin123
Aug 25, 2021Tutor
Thanks for the useful information
Firmware V2.7.3.22 (GUI language version V1.0.0.375)
The router supplied by the ISP is a Icotera Model: i4850-00.
The problem I have is that the walls are ~ 1 m thick stone and the Orbi satelites can talk through the wall when they are placed each side...
The reboot usually happens when I am connected to the server unit - and happens during video calls - and this makes it very annoying. I have enabled the WiFI on the Icotera router with a different Wifi name - and this works without problem [i.e. never hangs] so I can join that network if I am making a critical video call.
Each firmware update I hope that Netgear would solve this problem. I have tried many variations to try and find a solution to this continuing rebooting - but so far I have failed. I am not alone with this problem and I would have thought that Netgear would either offer a hardware fix - or fix the firmware - instead their service department say that I should throw it away and buy something new : unbelivable.
I will go through your list of suggestions ... but I fear that there will be no magic solution
Aug 25, 2021Guru - Experienced User
What mode is the modem working in? Router or Bridge?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
You might try option #3...
- Crispin123Aug 25, 2021Tutor
Thanks for this suggestion re the AP mode (option 3) I will try this ... :)
- FURRYe38Aug 25, 2021Guru - Experienced User
đ
- CrimpOnAug 25, 2021Guru - Experienced User
I did not see mention of the electrical supply to this Orbi.
- Is it on any sort of UPS?
- Has the power supply been swapped with a satellite power supply?
- Has the power supply been plugged into a different outlet?
My Orbi has been in operation for 126 days. Even my hyperactive imagination cannot come up with an explanation for what would cause a router to spontaneously reboot. besides losing electrical power.
In a post on a different subject, I saw mention of a Panic Log. There is an option on the orbi debug page (http://orbilogin.net/debug.htm) to Start debug log capture on boot up. The option to Save debug log will copy a zip file to the user's computer. Inside the file debug-log.zip there are many (many) files, and one of them is panic-log.txt (Mine is empty)
