StenkaRazin
Aug 16, 2019Aspirant
Orbi RBS50 reset does not respond
I own three RBS50 satellites, two of which work perfectly (both in wired mode). My Router is an RBR50, firmware version V2.3.5.30. I set up the entire system myself, and am familiar with syncing an...
StenkaRazin
Aug 18, 2019Aspirant
Thanks FURRYe38. I executed factory resets before, and have read both the manuals and every possible post on that topic, so I know what sequence to expect. I would be ready to assume that the ring led light is failed, but since I am not even detecting any signal from the unit when it's hard wired directly into my ethernet switch, I am rather guessing that power is not getting past the led light.
The satellite is less than a year old, and still under hardware warranty, so I can request an RMA. I was just hoping someone here would have a magic trick or workaround.
Thanks again !
Aug 18, 2019Guru - Experienced User
Hope the replacement works.
Good Luck.
