Kentschmitt21
Aug 16, 2019Aspirant
Orbi Rbs50 satellite being slow
I have 400 mgb Spectrum internet speed and recently just had a tech come out to check on some issues I’ve been having. I can run speed tests at my main computer that’s hardwired to the orbi router and...
ekhalil
Aug 16, 2019Master
- How do you see the Satellites attached to the Router in the Orbi app, in star or Daisy Chain topology?
- Do you have Daisy Chain activated in the advanced wireless settings?
Kentschmitt21
Aug 17, 2019Aspirant
I’ve been through my settings and nothing seems to help it. I have noticed that when I reset my whole system and set it up again that it won’t let me register it through NETGEAR again so I can use the dynamic dns. Ever since then i believe I had this problem. If it’s not that then it has to be some backhaul issue I keep reading about with no answers or a firmware issue I have to manually fix. Right now it’s running the v2.3.5.30. Nothing in seething has changed the outcome. Or moving the satellites closer to the router.
