mpdono
Jul 09, 2021Aspirant
Orbi RBS50 Satellite Blue, but not connected completely?
I have a 6 satellite system that has worked great for some time, but all of a sudden my Orbi RBS50 Satellite in my basement has started acting up. I can't wrap my head around what the problem is giv...
mpdono
Jul 10, 2021Aspirant
Yes, unforunately I needed extra satellites, I think due to the length of the house.
This particular satellite hasn't had an issue for 2 years until now.
Yes, all RBS satellites have the same FW as the RBR.
mpdono
Thanks for chiming in, I figured it out. After testing a different satellite in that location, I had the same problem.
I then was able to narrow it down to the problem only occuring when some of my other devices were plugged into the back of the satellite.
I recently had to get a Sonos Boost for different reasons and it appears to me that it changed the ZonePlayer, which was plugged into the satellite having issues, was trying to connect wirelessly and through the wired connection at the same time.
For whatever reason, while this was happening, the satellite would drop in and out repeatedly.
Unplug the Sonos ZP1 and the satellite works like a champ.
- FURRYe38Jul 10, 2021Guru - Experienced User
Sonos has there own wifi radios I believe. Something you might look into with Sonos and see what can be done there.
Glad you figured it out.
Please mark your thread as solved so others will know.
Enjoy. 📡
