ChuckieCheese
Dec 06, 2019Luminary
Orbi RBS50 satellite kept going in loop (Config Sync -> Poor -> Good - Config Sync)
I have the RBR50 with 2 satellite (RBS50). One of the satellite just went awry and from the router "Attached Devices" page, it kept showing Config Sync, Poor, and then Good and back to Config Sync ov...
CrimpOn
Dec 06, 2019Guru - Experienced User
Did you "unzip" the download? The Orbi firmware update is looking for an ".img" file.
ChuckieCheese
Dec 07, 2019Luminary
CrimpOn wrote:Did you "unzip" the download? The Orbi firmware update is looking for an ".img" file.
Yes, I did. I finally able to get the firmware updated by following this steps:
1. Update to 1.12 first
2. Update straight to 2.3.5.34, bypassing the "required" 2.2.1.210
Netgear need to check the RBS50 firmware 2.2.1.210.
