ChuckieCheese
Dec 06, 2019Luminary
Orbi RBS50 satellite kept going in loop (Config Sync -> Poor -> Good - Config Sync)
I have the RBR50 with 2 satellite (RBS50). One of the satellite just went awry and from the router "Attached Devices" page, it kept showing Config Sync, Poor, and then Good and back to Config Sync ov...
Dec 08, 2019Guru - Experienced User
to get from v1 versions of FW to v2x you first need to install v2.0.0.74 FW on the system, RBS first then RBR. Then you can go directly to v30, 38 or v40 on the RBS. You'll need v210 or v212 loaded next on the RBR then after that, v30 or later on the RBR. v210 and v212 are only ment to be intermediate FW update files to get the system up dated to a certain point.
ChuckieCheese wrote:I finally able to get in to the satellite web GUI and I tried to update the firmware. Per Netgear website, I MUST use v2.2.1.212 first since my current version V1.12.0.18
I download v2.2.1.212 from https://kb.netgear.com/000060612/RBR50-RBS50-Firmware-Version-2-2-1-212 and selected the 2nd link for RBS50.
Tried to do a manual firmware update and the satellite firmware update page threw this warning:
"Please select correct configuration file."
I am confused now. What am I supposed to do now?
I tried to upload the firmware using 4 different computers, 3 browsers (Chrome, Firefox and Safari and same result). I also downloaded the firmware 4 times already (using for 4 differrent computers), all connected to 3 different network (Verizon, Xfinity and AT&T). So it's got to be the firmware file.
ChuckieCheese
Dec 08, 2019Luminary
FURRYe38 wrote:to get from v1 versions of FW to v2x you first need to install v2.0.0.74 FW on the system, RBS first then RBR.
It didn't work. The RBS50 will not accept anything on v2.x (i tried v2.x one by one up to v2.2.1.212) and that's why I had to update to v1.12.0.18 first then straight to v2.3.5.34.
Maybre because my firmware is so old the RBS50 won't accept v.2.x? Not sure.
- FURRYe38Dec 09, 2019Guru - Experienced User
Well sounds like you got it updated anyways. Enjoy. :smileywink:
