Michael38125
Aug 13, 2019Tutor
Orbi RBS50 Satellite Not Powering on Correctly??
I have had my orbi system for over a month now and it has worked great espcially with gigabit internet speeds, but just recently I have had issues with one of my satellites. It should be noted the wh...
CrimpOn
Aug 13, 2019Guru - Experienced User
Pulsing green is not one of the things the Orbi ring light is supposed to do. GOOGLE "what do the LEDs on my orbi".
Orbi satellites "reset to factory" the same as the router. Stick the end of a paperclip in the "reset" hole until the power LED begins to flash amber.
- Michael38125Aug 15, 2019Tutor
I have looked it up before as pulsing green was not in the manual. Others have discussed the pulsing green issue here on the forums, which was somehow linked to power issues.
