Michael38125
Aug 13, 2019Tutor
Orbi RBS50 Satellite Not Powering on Correctly??
I have had my orbi system for over a month now and it has worked great espcially with gigabit internet speeds, but just recently I have had issues with one of my satellites. It should be noted the wh...
Michael38125
Aug 15, 2019Tutor
Although I did not find a solution, I was on the phone with NETGEAR tech support for over an hour and a half and they were unable to solve the issue I was having. Thus, they are sending me a replacement satellite. I would like to keep this forum/discussion open incase it occurs again, or if others are experiencing the same issue.
Thanks and any further information on why I was having this issue in the first place would be greatly appreciated.
Aug 15, 2019Guru - Experienced User
Glad NG is getting you a replacement. That was going to be a next suggestion.
Good Luck.
- SkipholidayOct 29, 2019Guide
I have the same issue. Have tried resetting and power light never changes to amber.
I've tried 30/30/30 and no change.
TFTP does not work, It's not recognized by the lan adapter so can't ping it.
I will continue trying. I currently have 4 RBS50's and they work awesome.
any insight would be appreciated.- Michael38125Oct 29, 2019TutorI am the original thread poster and I had to end up sending it to Netgear for a full replacement. Hopefully they can fix whatever is going on.
- SkipholidayOct 29, 2019GuideThanks for the quick reply. I have no warranty so it's up to me to fixit.
