Stallion69
Dec 02, 2020Tutor
ORBI RBS50 Satellite
One of my satelittes keeps pulsating white and will not stop. I disconnected it for a week because i was remodelling my office. I rehooked it up and it won't go online. I have both satelittes hook...
Stallion69
Dec 16, 2020Tutor
The router just keeps dropping out. All is green when connected with “Anywhere Access”. Can’t surf sites or nothing.
Dec 16, 2020Guru - Experienced User
This happens with just the RBR? No RBS connected, just turned OFF?
- Stallion69Dec 16, 2020TutorCogeco is my service provider. I’m located in Ontario, Canada. I switched to the 1 Gig modem for faster speeds. The Orbi will work off and on. When I power cycle everything it works again just for a little while. Luckily I have another ROUTER for back up that I can use. This is very frustrating.
- Stallion69Dec 16, 2020TutorThe modem my provider gave me.
- FURRYe38Dec 16, 2020Guru - Experienced User
Your ISP modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop - Stallion69Dec 17, 2020TutorThe wifi is already disabled on the modem from day one. I use my Orbi as the router.
