jkraebel
Sep 21, 2019Aspirant
ORBI RBS50 stopped connecting and cannot get it to connect back to router
I have at the RBR50/RBS50 Mesh system for almost 3 years and recently experienced some connectivity issues on the satellite unit (RBS50) and today it has disconnected and am not able to get it to rec...
CrimpOn
Sep 21, 2019Guru - Experienced User
Did you restart the RBR50 (router)?
When the satellite turns magenta, that means that the satellite thinks it is working, but it is not getting an IP address from the router.
https://kb.netgear.com/31018/How-do-I-sync-my-Orbi-router-and-satellite
You might try saving the configuration file to your computer, doing a "factory reset" on the router, and then reloading the configuration file.
(because it is such a chore to do a complete setup)
If loading the config file also fails, then the last step is a factory reset and complete setup on the router.
Even if you order a completely new system from Amazon today, you will be without a satellite for 24-48 hours, which leaves plenty of time to fool around.
Needing a new satellite does raise the question of (a) sinking more money into a technology that is "gradually becomming obsolete" or (b) taking the plunge and investing in the newest technology. If you need coverage now, getting WiFi6 means picking a completely new product. The Orbi WiFi 6 is not scheduled to ship until the end of October.
Sorry I don't have any quick solutions.
- jkraebelSep 22, 2019Aspirant
Thanks for the suggestion as that seems to have resolved the issue. I rebooted the RBR and power cycled the RBS and was bale to see it again.
