pmoff's avatar
pmoff
Orbi RBS50 Will not factory reset
My Obri Satellite (RBS50) went crazy about a month ago.  It started dropping off the network and I noticed that the halo on top would blink green.  The LED on the power button was on and solid green ...
  • pmoff's avatar
    pmoff
    Jan 15, 2019
    Thanks again for everything.  I called Netgear support and they also could not resolve the problem.  They are going to send me a new satellite and I have an RMA case open.  Thank you again for your helpful response.
