pmoff
Jan 11, 2019Aspirant
Orbi RBS50 Will not factory reset
My Obri Satellite (RBS50) went crazy about a month ago. It started dropping off the network and I noticed that the halo on top would blink green. The LED on the power button was on and solid green ...
- Jan 15, 2019
Thanks again for everything. I called Netgear support and they also could not resolve the problem. They are going to send me a new satellite and I have an RMA case open. Thank you again for your helpful response.
Jan 11, 2019Guru - Experienced User
I would contact NG support and get there help on this. Seems like the satellite maybe bad.
pmoff
Jan 15, 2019Aspirant
- Chuck_MJan 15, 2019Mentor
Dont forget to mark this resolved.
- FURRYe38Jan 15, 2019Guru - Experienced User
Glad support will send you a new unit.
Let us know how it goes when you get the new unit in.
:smileywink:
