rjames77
May 25, 2019Aspirant
Orbi RBS50 Will not factory reset
Hi, I have a new Orbi Wifi router and the default admin password does not work. I've tried going through the recovery process but I never set up the security questions that it's now asking me t...
- May 26, 2019
Thanks FURRYe38 and CrimpOn,
I tried it again tonight holding the pin for 20 seconds, I saw the exact same light sequence as I saw with the earlier attempt but today it worked. I can only assume that I did something wrong the last time.
Thanks for you assistance,
Robin
rjames77
Hi CrimpOn,
Yes, I held it for around 10 seconds and saw the blinking amber light. I did it twice just to be sure.
Thanks,
Robin
Thanks,
Robin
CrimpOn
May 25, 2019Guru - Experienced User
I just noticed the title: "RBS50", that's a typo, correct? The RBS (satellite) certainly can be reset, but the RBR (router) is what controls everything.
And, no. The RBR50 not being able to reset is not a "known issue." Users report restting them successfully all the time.
