rjames77's avatar
rjames77
Orbi RBS50 Will not factory reset
Hi,     I have a new Orbi Wifi router and the default admin password does not work.  I've tried going through the recovery process but I never set up the security questions that it's now asking me t...
  • rjames77's avatar
    rjames77
    May 26, 2019
    Thanks FURRYe38 and CrimpOn,
        I tried it again tonight holding the pin for 20 seconds, I saw the exact same light sequence as I saw with the earlier attempt but today it worked.  I can only assume that I did something wrong the last time.
    Thanks for you assistance,
    Robin
