Timo002
Nov 17, 2020Tutor
Orbi RBS50 wired backhaul but keeps using wireless
Hello, I have read a lot on this issue on this forum. But nothing found for my issue yet. I have connected the satellite with a ethernet cable through a router, but the backhaul between the O...
- Nov 17, 2020Ok, I managed it this way:
Internet
TP-Link ———RBS50
RBR50
Now the RBS50 uses the wired backhaul!
Tnx!
Nov 17, 2020Guru - Experienced User
You must connect the RBS directly behind the RBR or via a middle LAN switch that is also connected behind the RBR to get the RBS to sync up and work on wired ethernet backhaul:
It won't work as you have it connected currently.
