Frank70
Apr 10, 2019Aspirant
orbi RBS50 wrong wifi name on bottom sticker
when i want to install the Orbi router , it is asking to connect through wifi of the Orbi rbs50 ,
the wifi and password is mentioned on the bottom of the device ,
BUT the wifi that is popping up ...
Frank70
Apr 22, 2019Aspirant
i could connect fianlly the Router but the sattelites want connect
i ahve reset them , but the power button continues to blink red and i cant connect them at all .
CrimpOn
Apr 22, 2019Guru - Experienced User
Frank70 wrote:
I could connect finally the Router but the sattelites won't connect
I have reset them , but the power button continues to blink red and I cant connect them at all .
When the power LED blinks red, the satellite may be broken. Here's what Netgear's web site says about the power LED:
Router and satellite power button LEDs
Solid green. Your Orbi router and satellite are powered on.
Solid amber. Your Orbi router and satellite are rebooting.
Pulsing amber. You must reset your Orbi router and satellite to factory default settings.
Pulsing red. Your Orbi system might need attention. Contact support.
