Frank70
Apr 10, 2019Aspirant
orbi RBS50 wrong wifi name on bottom sticker
when i want to install the Orbi router , it is asking to connect through wifi of the Orbi rbs50 ,
the wifi and password is mentioned on the bottom of the device ,
BUT the wifi that is popping up ...
Apr 24, 2019Guru - Experienced User
You'll need to file a support ticket and get the RBS replaced:
https://www.netgear.com/mynetgear/registration/login.aspx
Frank70 wrote:
1 satelite is now green but doest connect and also i cant reset it anylonger , even after holding reset button for over 20 sec
the second satelite continues to blink red and nothing happens
