Cmp55498
Apr 02, 2017Tutor
Orbi RBS50
I have a desktop running Windows 10 at the far end of the house from a RBS50 satellite. Unfortunately, while the signal remains strong, the internet disconnects a lot. I will be working and it will...
peteytesting
Apr 02, 2017Hero
Cmp55498 wrote:I have a desktop running Windows 10 at the far end of the house from a RBS50 satellite. Unfortunately, while the signal remains strong, the internet disconnects a lot. I will be working and it will drop 5-10 times in an hour. I used to use the TP-Link TL-WDM3200 and it has a known issue with the driver in windows 10. I am currently using the ASUS AC55 with the same issue.
i dont understand , where is the orbi router in this setup , the sat being at the other end of the house means the orbi router should be in the middle right ? and you would be connecting to the orbi router and not the sat ? or is the orbi router in another house
