mckin's avatar
mckin
orbi RBS50v2 firmware updates
Just purchases yesterday. Followed setup on line. The router did the update and 1 satelite did. 1 Satelite did not do firmware update. Can someone help me proceed.
    • mckin's avatar
      mckin
      It is no longer connected so I cannot manually update it. Is there a way to reconnect it?
      • FURRYe38's avatar
        Try this:
        What you need to do is factory reset the RBS. Wire connect a PC to the satellite. Already have the most current FW version files downloaded on to this PC. Press the reset button on the back of the RBS for 15 seconds then release.
        When the satellites are reset, wait about 5 minute. The PC will get a IP address from the satellite. The IP address of the satellite will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites web page FW update feature to select the FW update file that was unpacked from the .zip file. Do this for both satellites. Then factory reset and then re-sync the satellites to the RBR.
