Osh1917
Mar 23, 2025Aspirant
Orbi RBS50v2 Satellite Pulsing White Continuously
Hi. Hope someone can help. One of my three Orbi RBS50v2 satellites stopped connecting to my RBR50 router. Could not get it to sync again. When powering on the satellite, the LED on the back by th...
Osh1917
Just an update in case it helps...
When powering on the satellite, the LED on the back by the power button is constant green (not flashing green) for a few seconds, then flashes red continuously.
Have tried a different power supply, just in case that was causing the issue - no luck.
Also, when trying the nmrpflash utility to try to update the firmware, have tried it on two Windows computers, so two different LAN connections. The utility just isn't communicating with the RBS50v2 satellite, making me think it is dead.
- FURRYe38Apr 01, 2025Guru - Experienced User
Most likely. Can find used RBS50s on ebay or shopgoodwill
Good Luck.
