HenryXia05
Apr 28, 2023Aspirant
Orbi RBS50v2 showing only connected devices and firmware update
Hello, I would like to know how to fix when I'm connected to my orbi's WIFI it only shows connected devices and firmware update, I cannot change the SSID or password since there's no setting for ...
Apr 30, 2023Guru - Experienced User
The orbi satellite ssid is tied into the primary routers ssid. Its why its a mesh system and its why you can't change it on the satellite.
It has to be changed on the router.
- HenryXia05Apr 30, 2023Aspirant
So I am using the fios router and the Orbi as an access point, though they are on the same network, I would still like to be able to change the SSID and the password. I went to my verizon router and I couldnt change it either
- CrimpOnApr 30, 2023Guru - Experienced User
The Verizon router management screens can be used to manage the Verizon router itself, not devices connected to the router.
Find the IP address of the Orbi base unit (RBR50) and open a web browser to that IP address.
The Wireless menu item is where the WiFi SSID and password are set.
Or, the Orbi 'app' can be used to change these settings.
That is what I did, I typed the IP address and there are no settings for SSID, I think it might be because its a mesh as mentioned before.
