pgrosejones
Aug 07, 2019Follower
orbi RBS50Y Windows 10 laptop wont connect. All driver updates are done.
Hi, My windows 10 laptop wont find the Orbi outdoor via wifi. It finds the house wifi which is 50mts further away and I can hot spot my phone quite easily. My iphone and ipad find the Orbi straight ...
Aug 08, 2019Guru - Experienced User
If your laptop won't connect to an unsecure wifi SSID, then you'll need to look into Windows settings or the laptop hard ware. If other devices are connecting and this one laptop won't, problem will be with this laptop.
What happens if you set up WPA2 and AES only on the Orbi system and RBSY? Will the LT connect then?
pgrosejones wrote:Hi, My windows 10 laptop wont find the Orbi outdoor via wifi. It finds the house wifi which is 50mts further away and I can hot spot my phone quite easily. My iphone and ipad find the Orbi straight away. Strangely enough I can see it in Manage known networks but it doesn't have any details attached. I have set it up as unsecure would that be it ?
I would really like some help. Thanks Pete
