neeliec
Aug 21, 2019Tutor
Orbi RBS50Yv2 compatible with existing router?
I want to puchase the Orbi RBS50Yv2 outdoor range extender. Will it work with my existing Amped Athena router conneced to my cable service?
- Aug 22, 2019
Yes, the Orbi Outdoor can be set up in Extender Mode which will let you use it with an existing, non-Orbi router. For more info, please check out this KB article on how to set that up: https://kb.netgear.com/000060131/How-do-I-set-up-my-Orbi-Outdoor-Satellite-in-Extender-Mode
neeliec
Aug 28, 2019Tutor
neeliec wrote:I want to puchase the Orbi RBS50Yv2 outdoor range extender. Will it work with my existing Amped Athena router conneced to my cable service?
I recently asked ^ ^ ^ if the Orbi RBS5OY extender could be used with my existing Amped Athena router. Some repliies stated NO and a couple said yes. I contacted Netgear directly and was told it WILL work with existing routers. This is from the Costco webpage where I intend to purchase:
Works with any WiFi router or gateway
Use your existing WiFi equipment to extend your current WiFi coverage outdoors to the garden, pool, garage, and other areas that are usually out of WiFi range. Enjoy uninterrupted video and music streaming on all your devices for seamless entertainment anywhere in your property.
So just a FYI for anyone else considerin purchasing the Orbi RBS5OY.
