cristmo
Oct 26, 2021Aspirant
Orbi RBS50Yv2 Router - How can I install the Orbi app for my system if my modem is in bridge mode?
I've had my Orbit mesh system with two satellites for over a year. Things have worked fine with one exception. When I perform a firmware upgrade, my Orbi app can no longer recognize the router or t...
- Oct 27, 2021
Thank you for sending me to the right forum. I'll try those.
CrimpOn
Oct 26, 2021Guru - Experienced User
I confess to being a bit confused by terminology. Is this the situation:
- The existing system is an SRR60 router with one indoor and one outdoor satellite (RBS50Y in extender mode).
- The SRR60 is in Access Point (AP) mode.
- The Orbi 'app' is able to connect to the SRR60 and do some management things.
(Not a LOT of management things because AP mode disables quite a bit:
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode ) - Doing a firmware update on the SRR60 causes the Orbi app to no longer connect to the SRR60?
Smith008
Oct 27, 2021Aspirant
CrimpOn wrote:I confess to being a bit confused by terminology. Is this the situation:
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode )- Doing a firmware update on the SRR60 causes the Orbi app to no longer connect to the SRR60?
Hello,
Everything is very open with a clear description of the issues. It was truly informative. Your website is very helpful. Many thanks for sharing!
