cristmo
Oct 26, 2021Aspirant
Orbi RBS50Yv2 Router - How can I install the Orbi app for my system if my modem is in bridge mode?
I've had my Orbit mesh system with two satellites for over a year. Things have worked fine with one exception. When I perform a firmware upgrade, my Orbi app can no longer recognize the router or t...
- Oct 27, 2021
Thank you for sending me to the right forum. I'll try those.
Oct 27, 2021Guru - Experienced User
Orbi app is not supporting of Orib Pro systems. Orbi Pro uses InSight app to connect to those systems.
If your trying to get the RBS50Y to connect to your Orbi Pro system, not sure if the Orib app can or get pass thru data to the RBSY thru the Orbi Pro.
For Orbi Pro support, Netgear has set up a community forum specifically for the Orbi Pro products. Most of the people who watch that forum are more likely to have experience with Orbi Pro and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
Netgear has set up a community forum specifically for the Orbi AC products. Most of the people who watch that forum are more likely to have experience with Orbi and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-pro-wifi
Thank you.
cristmo
Oct 27, 2021Aspirant
