bwebster1970
Apr 27, 2021Follower
Orbi RBS850 - piece of crap
Like many others, I am having nothing but problems with my Orbi RBS850 router. I can configure the router fine and it works great, unless I try to block a device. After I block a device, the rou...
Apr 27, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
