arees0921
Mar 19, 2021Tutor
Orbi RBS850 Parental Controls
I have a RBS852 AX6000 Orbi Router and 3 satellites. The model number does not appear in this community support... which is very odd.
Does anyone know where to setup parental controls per device using the Orbi Router software? Seems I can allow or block devices, that's it
1 Reply
- vajimMaster
arees0921 wrote:I have a RBS852 AX6000 Orbi Router and 3 satellites. The model number does not appear in this community support... which is very odd.
you may want to post your question here:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
