kwangomango
Feb 18, 2021Tutor
ORBI RBS/RBR 40 UPNP not working when device connected to satellite
I'm having exactly the same issue as described in this thread: https://community.netgear.com/t5/Orbi/ORBI-UPNP-not-working-when-device-connected-to-satellite/td-p/1544717 but the solution of dis...
vajim
Feb 18, 2021Master
- kwangomangoFeb 18, 2021Tutor
Hi
UPNP is already enabled on my router. This issue i'm describing is that the Orbi satellite is not forwarding the requests to the router.
- vajimFeb 18, 2021Master
well I'm guessing it did work and now it doesn't...??
if that's true what changed?
firmware?
Thanks for your assistance but can i suggest you read my original post again and the post i have linked to so that you can be clear what the problem i'm facing is.
